lschm.2
January 10, 2023
Could you explain me what is the "input Current" named in the figure 5 of TS391 comparator datasheet compare to the input bias current and input offset current?
Could you explain me what is the "input Current" named in the figure 5 compare to the input bias current and input offset current?
Thanks,
    Pierre SENNEQUIER
    This curve shows the input bias current. Which is the average current getting out of the input pins.
    Iib=(Iib+ + Iib-)/2. (when the op amp is used in linear, not as a comparator)
    The input offset current is the difference between the current off the two inputs. Iio=Iib+ - Iib-
    Best Regards,
    Pierre
    "In order to give better visibility on the answered topics, please click on ""Accept as Solution"" on the reply which solved your issue or answered your question."
