SLee.9
CO Gas Concentration Reading with the board P-Nucleo-IKA02A1.
​I'm trying to tuning CO​ Gas reading value with the board P-Nucleo-IKA02A1.
By the P-Nucleo-IKA02A1 BSP, Get_Gas_concentration function is belows..
​float Get_Gas_concentration(float gain, float sens){
return ((float)Get_ADC_value(ANALOG_GAS_VALUE_PIN)-Get_ADC_value(ANALOG_REF_VOLT_VALUE_PIN))*805664/gain/sens; }
What's the meaning of the constant, 805664, of above source code?
    Jiri HLADIK
    This constant represents conversion from ADC value to voltage. One LSB of 12bit ADC powered from 3,3V represents 805,664uV
    The value is multiplied by 1000 to have correct gas concentration reading in ppm
    Best regards
    ST support
    SLee.9
    SLee.9Author
    Thanks for your quick answer.
    Dsaka.686
    October 29, 2019
    STM32 Nucleo sheets give a moderate and adaptable path for clients to explore different avenues regarding new thoughts and manufacture models with any STM32 microcontroller line.
    Tutuapp 9Apps ShowBox
