Choosing Decoupling Capacitors Values for TS482IDT audio amplifier.
We have an audio amplifier circuit in our design using the TS482IDT chip. We're wondering if there's any guidance on what is a good value for decoupling capacitors for the chip? Is 0.01uF acceptable? Or Could we use 0.1uF?
Thanks,
AScha.3
AScha.3Best answer
no calculation. :)
just : this is an audio amp, so you want a cap, thats effective at frequencies < 20 kHz, but also filtering/reducing high frequ. input (spikes, noise ) ; and cheap - matching the amp price range -> ceramic caps now cheap, even in "big" values (for decoupling caps) , so i use 10u /25V X7R in 0805 size (about 10ct ); if your supply is good for audio (low impedance, low noise ) this 10u is all you need. (close to chip )
Issamos
Hello @Kenny03
You can find her the values of the Input coupling capacitor (Cin):
And the values of the Output coupling capacitor (Cout):
Also, you have a typical application schematic that you can use:
For more details, refer to the this document .
Best regards.
II
AScha.3
..he write: decoupling , not coupling.
Issamos
Thank you for the rectification. @AScha.3. It was careless mistake.
AScha.3
decoupling ...power supply ? for audio, 10u minimum close to chip, and 470uF elko somewhere.
Kenny03Author
This helps thanks, could you please give some insight as to how you arrived at 10uF? I'd like to understand the calculation or rationale behind this number.
AScha.3
AScha.3Best answer
no calculation. :)
Kenny03Author
Awesome thanks for the info. This helps.
