son1
5 samples latency on STA321MPL?
Posted on October 13, 2016 at 04:50
My SW read audio with PCM format from STA321MPL. The same time it read PDM format from Digital Microphone. Both are set with 16 Khz sample rate. It always has
5 samples delay in audio signal from STA321MPL compare to audio signal from digital Mic. All are set the same source clock. I have reviewed my code but could not find anywhere lead to this delay.
Nickname1623_O
October 18, 2016
Posted on October 18, 2016 at 04:28
hi Le_son,
the conversion from PDM to PCM is similar with AD conversion , and normally  group delay will be introduced in processing channel .
so it's normally behavior for audio processor .
YT
