Code works in another board, but not in my custom board.
  • July 22, 2025
  • 4 replies
  • 886 views
Original title: Facing a debug issue. the code works in another board and gets firmware update. but its not working in my current stm32f103zet6 customized board.
Shortened in accordance with Posting Guidelines .
anuradhaAuthor
and i checked in st link utility ,the firmware is upgrading but in stm32cubeprogrammer its not even connecting when i try to upgrade it its started upgrading at the end its saying the st link connection is lost ..whyy??
Andrew Neil
Welcome to the forum.
Please see How to write your question to maximize your chances to find a solution  for best results.
Please give details of this board.
And also details of this board - schematics, etc.
Note that the ST-Link utility is long obsolete - STM32CubeProgrammer is the current tool.
Is this with the original board, or the "custom" board?
What CubeProgrammer version?
What ST-Link are you using? Is it a genuine ST-Link?
See: How to recognize a genuine ST-LINK/V2 versus a cloned one.
Please show the full log from CubeProgrammer; also a screenshot.
anuradhaAuthor
It worked after erasing full chip. But i have a question In my stm32cube programmer whenever i connect my target board its showing the only message like "Ur connection mode is defined with HWrst reset mode .Iam using 2.20.0 stm32cube programmmer version
I put mode: under reset
reset mode: hardware reset
and if i click option bytes option also its still sending the same message....
Andrew Neil
@anuradha wrote:
 message like "Ur connection mode is defined with HWrst reset mode....
Please show the actual message.
And a screenshot showing your settings.
You still haven't given any details of the boards you're using.
Andrew Neil
@anuradha wrote:
I am using stm32f103zet6 board.
That's just a chip part number - it tells us nothing about the board.
You need to post the schematic and/or a link to the manufacturer's page for the board.
@anuradha wrote:
Not only this every board i connected its showing same message.
You said in your original post that one board did work?
This is not a valid ST-Link serial number:
So your ST-Link is either fake or faulty - or both.
Again, see: How to recognize a genuine ST-LINK/V2 versus a cloned one.
In particular, see:
https://community.st.com/t5/stm32-mcus/how-to-recognize-a-genuine-st-link-v2-versus-a-cloned-one/tac-p/703663/highlight/true#M965
Tesla DeLorean
Guru
July 22, 2025
Show picture of board and ST-LINK.
Show picture of STM32103ZET6 IC that's problematic, large, clear and in-focus if you can manage that.
Details so far suggest you are working with fake/counterfeit parts.
Tips, Buy me a coffee, or three.. PayPal VenmoUp vote any posts that you find helpful, it shows what's working..
