waclawek.jan
USART BRR above 0xFFF7 hangs the Tx
  • October 3, 2017
  • 528 views
Posted on October 03, 2017 at 13:24
    Nesrine M_O
    Posted on October 03, 2017 at 15:12
    Hi
    Waclawek.Jan
    Could you please provide more explanation on your case, so that it will be easier to understand the issue?
    -Nesrine-
    waclawek.jan
    Posted on October 03, 2017 at 23:17
    Nesrine,
    in an STM32F407, I enabled USART6's clock in RCC, and set USART_CR1.RE and USART_CR1.TE and USART_CR1.UE.
    If I write 0xFFFF into USART_BRR, then write any byte into USART_DR, in USART_SR the TXE bit is cleared and remains so indefinitely; and there's no activity on the respective Tx pin.
    If I write 0xFFF7 into USART_BRR, the byte which has been written above is output properly onto Tx pin and TXE bit is set in USART_SR.
    All BRR values between 0xFFF8 and 0xFFFF appear to behave in this way.
    Jan
