Mira H. (deactivated upon user
SDIO change order of data pins
  • May 8, 2017
  • 3 replies
  • 1404 views
Posted on May 08, 2017 at 16:18
Hi everyone,
Is it possible to change the order of the data pins by software? I messed up and connected D0 with D3 and D1 with D2 and so on, between an STM32F765 and a WLAN Chip WL1807 (TI).
I'm using STM32CubeMX.
Best regards,
Mira
#sdio #stm32f765
S.Ma
Principal
May 8, 2017
Posted on May 08, 2017 at 16:49
Probably not, otherwise the Alternate function table in the datasheet would be meaningless.
Seems this will be handy:
http://sg.element14.com/roadrunner/rrp-a-105/wire-0-15mm-assorted-pk-4/dp/5017233?ost=5017233&categoryIdBox=&selectedCategoryId=&searchView=table&iscrfnonsku=false
May 8, 2017
Posted on May 08, 2017 at 17:03
Other than modifying the in-memory buffers, no.
Tips, Buy me a coffee, or three.. PayPal VenmoUp vote any posts that you find helpful, it shows what's working..
Posted on May 08, 2017 at 18:01
Thanks for answering so quickly.
I guess, scraping away the microstrip lines and rewiring won't work, since the four data lines need to be of the same length.
S.Ma
Principal
May 8, 2017
Posted on May 08, 2017 at 19:55
These are not differential lines. at 300ps per inch, it's doable
May 8, 2017
Posted on May 08, 2017 at 22:32
I've wire-wrapped without incident, reasonably consistent lengths are sufficient.
