SGasp.1
Jul 24, 2023 8:30 AM UTC
Reading internal temp of stm32 mcu gives you idea of the temp of pcb
Hi community.
I would like to know if reading the internal temp of the mcu (using the right channel of the adc) can give you an accurate idea of the temperature of the pcb where the mcu is mounted.
Is it accurate this temp?
Is it sensistive to other effects ?
Does it work to use this information?
Thanks a lot for your reply
    Tesla DeLoreanBest answer
    Aug 22, 2023 10:25 PM UTC
    Probably pretty awful.
    Used TMP116 (1/128 C resolution) and BMI160 (1/512 C resolution) devices here. Many IMU type devices have temperature sensors
    STOne-32
    Aug 22, 2023 9:17 PM UTC
    Dear @SGasp.1 ,
    This application note may interest you :
    https://www.st.com/resource/en/application_note/an5036-thermal-management-guidelines-for-stm32-applications-stmicroelectronics.pdf
    you can read Tj ( jonction die ) temperature and then using the data inside the Datasheet you may estimate board temperature if you have models of your PCB for thermal study.
    hope it helps you .
    Ciao
    STOne-32
