goobinooz
Problem GPIOs WeAct Board STM32F411CEU6 and STM32F401CEU6
  • January 6, 2024
  • 1 reply
  • 848 views
I can't program the GPIOs
levels don't change and stay in reset mode, what's the problem?
I use the HAL STMF4
Maybe you help me please!!!
Thanks for the advance!
STM32F4 Series
I use the HAL STMF4
Not much info you're giving us. Here are some possibilities, in order of likelihood:
  • Code bug (show your code, or go from an example)
  • Misunderstanding (perhaps you are monitoring the wrong pin, or the pin isn't connected how you think.)
  • Hardware issue (solder bridge, broken trace, cold joint, etc.)
Consider going off of an example and adapt it for your board:
https://github.com/STMicroelectronics/STM32CubeF4/tree/master/Projects/STM32446E-Nucleo/Examples/GPIO/GPIO_IOToggle
