Overclocking experiment - proved how large margins are in STM32G0
I tried to overclock STM32G030. I didn't need more speed and such operations should never be used in final product - only for curiosity.
But it's 64MHz according to specs. I ended at 160Mhz. Room temperature, 3.3V power supply
Tested with rather simple program but one acccessed RAM, FLASH and used UART to output result of quite simple calculations. At 160MHz it still worked. It felt cool to touch.
What that means is that it CERTAINLY will run at 64MHz at highest or lowest allowed temperature, lowest allowed voltage and still with some margin.
