Interference of DAC output and the PWM
Posted on August 13, 2014 at 07:21
I am generating a signal which goes to output of the DAC, but unfortunately when I use the PWM module of the system the PWM signal frequency distorts the signal generated by the DAC.Can anyone tell me what is the problem and if there exist a solution.Regards
