How to round division on STM32G0
I'm trying to implement an integer division with rounding. Obviously, by default integer division does floor and I was thinking I could use the remainder to determine if I should add 1 to my result.
Processor cycles are at a premium in this solution (running at 10s of kHz), so I'm seeking ways to do this with minimal overhead or ideally get the result "for free" as part of the existing division calculation
My question is, does anyone know of a good way of achieving this on the G0 which does not actually have a division instruction. Do I need to go into the disassembly and just see what it's doing? Do I need to write my own assembly code? Are there accepted solutions for this?
Note: Quotient and divisor are both arbitrary, and not constant integers.
