Lfu.11
How to measure the power consumption of discovery board?
  • October 20, 2020
  • 5 replies
  • 2021 views
I am developing a application with STM32F746G discovery board with my sensor, and I reference AN4749 to design a lop-power control flow.
But I don't know how to measure/monitor/analyzing the power consumption to make sure whether my design is work or not.
Is there any software tool that can do this? Or I need to buy another hardware tool?
Thanks for any kind support.
Best answer by TDK
Remove JP1 and use a current monitor in its place.
TDKBest answer
October 20, 2020
Lfu.11
Lfu.11Author
For now, my power supply is from USB(CN14).
Are you mean that I need to remove the jumper (5vlnkusb <-> 5v) and put my current monitor between those 2 pins?
Yes, it looks like all power comes through that connector. You could double check the schematic to be sure.
wired
Senior II
April 14, 2022
And if you really want to know what's going on in your low-power battery-operated system, buy a Joulescope! Best product for everyday embedded engineers in the past decade, IMO! I just keep mine attached to the board I'm working on and run it continuously.
