HAL_SPI_Receive_DMA() won't start a transfer in a CubeMX project that I cloned. No activity on SPI bus. HAL call returns success. .IOC and generated files all compare successfully. (only changed some GPIO, SPI is configured same) What could I be miss
I simply wanted to make an identical program but with a different GPIO pinout. The SPI busses are all on the same pins and configured the same. What could I have touched that would cause the SPI transfer to not start ? I had to switch to HAL_SPI_Receive_IT() as interim solution.
