maxime2399
ST72324 : jitter on MCO pin on PF4 set high ??!
  • October 28, 2002
  • 945 views
Posted on October 28, 2002 at 13:09
maxime2399
Posted on October 25, 2002 at 19:17
I have notice some jitter on my MCO clock signal when I set high PF4
which is configured as output push pull.
I have stripped down my code and I noticed that this jitter behavior is
also related to PA3 state (configured as input floating low level) and
CSS enabled.
Have you ever got this problem on your design ?
johan239955_stm1_stmicro
Your problem looks like a product limitation described in the ST72324 errata sheet. Check the October 2002 errata sheet (Rev. 5.1), paragraph 3.2.4.
Regards,
Jojo
