Sunny.Q
Sep 2, 2019 7:01 AM UTC
How can I get the quaternion matrix Q directly from LSM6DSO?
I download the document from your website, it shows how to rotate the coordinate, while the function it uses directly get the quaternion matrix Q which I cannot read from the board, can some one told me how to get this Q data?
Attached is the document downloaded from st web.
    Eleon BORLINI
    Sep 24, 2019 10:51 AM UTC
    Hi @Sunny.Q​ , to get the quaternions using an accelerometer and a gyro you canfollow the indications described in the design tip DT0060. To have a reference source code you can refer to the X-CUBE-MEMS1 UM2225 (MotionEC real-time E-Compass), the MotionEC_Manager.c file. Regards
    Sunny.Q
    Sunny.QAuthor
    Sep 24, 2019 9:52 PM UTC
    Thank you for your reply. Right now, I am applying the kalman filter algorithm to remove the drift,this is the process I must do in my project, there is a matrix R,which is the variance of the measurement. I read the paper says it should provided by the company. Do you have idea what that is?
    And another thing surprise me is, why your device even have no drift?After I run the device about 5 mins, the gyroscope is still very accurate? Does this device already have some inner functions to remove drift?
    Eleon BORLINI
    Sep 25, 2019 1:10 PM UTC
    ​Hi @Sunny.Q​ , I was wrong suggesting you the use of MotionEC compass library, which of course uses the axl+mag data. The right FW package is MotionFX one, in 6-axis mode. However, it's not directly possible to get the Matrix Q from that source code, too deep inside the algorithm. Sorry for the lack of help :crying_face: Regards
