STM32CubeProgrammer (MCUs)
STM32CubeProgrammer 2.18.0 released
STM32CubeProgrammer v2.18.0 release information New features:  Added the support for the STM32N6 series– OTP programming– External memory programming– Serial boot via USB/UART– FSBL signature with stm32header V2.3 through the signing tool• Added the ...
In cubeprogrammer unbale to add start address
Hello,I am working on NUCLEO-H7 board . Its dual core CM7 and CM4. When I Erase the full flash then I click into erase and programming option but I unable to add start address . The core M7 is get programming , but in Core M4 i unable to do programmi...
MDeva.1 by Associate II
  • 1248 Views
  • 8 replies
  • 1 kudos
Not able to connect with stm32 cube programmer
Dear sir, I want to connect my stm32 board with stm32 cube programmer. ​but there is some issue, 1.i am able to read the device number , but the connect led does not turn green 2. Then I get messages of check boot configuration and serial port.3. I...
NSane.1 by Associate II
  • 1479 Views
Resolved! Unable to run code STM32F411RET6
Hi,I'm unable to run code in my STM32F411RET6 when i'm running code, the debugger print :"Open On-Chip Debugger 0.11.0+dev-00449-g53fa0f7 (2022-06-09-09:40) Licensed under GNU GPL v2Info : Listening on port 6666 for tcl connectionsInfo : Listening on...
LBien.1 by Associate II
  • 2192 Views
  • 5 replies
Why this error flashing STM32F746BGTx ?
I'm trying to flash a .bin file onto STM32F746BGTx  with CubeProgrammer 2.6.0.Yes , not latest but STM32F746 is not quite a new thing so I'd expect it to work.And get this:16:11:01 : File : vvvvv.bin 16:11:01 : Size : 1026247 Bytes 16:11:0...
Pavel A. by Evangelist III
  • 373 Views
