STM32CubeProgrammer (MCUs)
STM32CubeProgrammer 2.18.0 released
STM32CubeProgrammer v2.18.0 release information New features:  Added the support for the STM32N6 series– OTP programming– External memory programming– Serial boot via USB/UART– FSBL signature with stm32header V2.3 through the signing tool• Added the ...
Resolved! Issue with the external loader with STM32H563
Hello everyone,I'm encountering an issue while using an external loader to program an external flash memory (MX25L6433F) on an STM32H563IGK6 board. My objective is to access this external flash (OCTOSPI1) with DFU for operations like erasing, writing...
Gnour by Associate II
  • 5373 Views
  • 21 replies
  • 3 kudos
Resolved! Text following version is in bold
The text printed to console after running "STM32_Programmer_CLI --version" stays in bold To reproduce :STM32_Programmer_CLI --version && echo "This shouldn't be in bold" The output:        -------------------------------------------------------------...
hnvseau by Associate
  • 791 Views
  • 4 replies
  • 3 kudos
Resolved! STM32CubeProgrammer J-Link issue
I'm trying to use the STM32CubeProgrammer with the newly supported J-Link settings, but can't seem to get it to work.I'm using:STM32CubeProgrammer: v2.17.0STM32H573I-DKSEGGER J-Link PLUS: SEGGER J-Link Commander V8.10c (Compiled Oct 16 2024 16:20:30)...
Resolved! Unable to connect to STM32H523
Hi,I am trying to connect to a STM32H523RET MCU via SWD using a J-link Debugger (CubeProgrammer v2.17.0).Reading the Product ID fails, so I get asked to select the MCU manually.Unfortunately the list does not contain any STM32H52x MCU But when I am t...
WhoIsJohnGalt_2-1727295663441.png WhoIsJohnGalt_3-1727295706101.png WhoIsJohnGalt_0-1727295541006.png WhoIsJohnGalt_1-1727295559401.png
Resolved! Cube programmer halts CPU
Hi, I hope someone can help me with this.I am using STM32CubeProgrammer 2.16.0 with an NUCLEO-H563ZI and Ubuntu 23.10. Programming, reading Registers seems to work. STM32CubeProg halts or runs my running or halted MCU approx every second depending on...
Resolved! STM32F746G Discovery: Failed to erase memory
Originally a reply here: https://community.st.com/t5/stm32-mcus-touchgfx-and-gui/stm32f746g-discovery-what-is-the-difference-between-cu2-and-cu4/m-p/746537/highlight/true#M40704  - moved to a new Thread for the new question. Thank you so much for you...
BA2 by Associate II
  • 484 Views
  • 1 kudos
