STM32CubeProgrammer (MCUs)
Ask questions on STM32CubeProgrammer and find answers on device detection, connection failure, programming issues, and more.
Resolved! STM32CubeProgrammer v2.22 released
We are pleased to announce that STM32CubeProgrammer 2.22 is available What is new in 2.22: Support for the STM32U3 microcontrollers with 2 Mbytes of flash memory: Internal memory programming through debug and bootloader interfacesOption bytes program...
STM32F103xx Assembly - unable to run application
I am "Learning" assembly, So I have tried to program my stm32f103 in assembly (a simple program to blink a led). The problem is that the program runs when uploaded using st-flash utility. But, If I press reset button, the program stops working.Here a...
Praveen1 by Associate II
  • 2158 Views
  • 3 replies
My STM32H743 MCU can not get into USB DFU mode, which has initial bootloader version 13.2 I got the wrong ic or there is another solution?
Hello ~My STM32H743 MCU can not get into USB DFU mode, which has initial bootloader version V13.2I follow the instruction, boot0 pin to high, plug usb, watching my device list, but there is no STM FS DFU device.I designed new board with stm32h743xi, ...
GLee.4 by Associate
  • 1788 Views
  • 1 replies
STM32F410 EXTERNAL LOADER CREATE
Good morningI am trying to create and use SPI EXTERNAL LOADER using STM32F410 CBT3. I created EXTERNAL LOADER using S25FL032P_STM32G071B_NUCLEO sent from STM. Data is read from STM32CUBEPROGRAMMER, but data mismatch found at address 0x90000000 occurs...
GGIL.1 by Associate II
  • 1444 Views
  • 1 replies
Resolved! External Loader with STM32CubeProgrammer
I created an external loader, I tried it with STM32CubeProgrammer. Most of the time its not working, rarely it can read the data and erase. When it happens I am trying to program the memory and it can program ~400 KB then it fails. Then I used ST-Li...
kb24 by Senior
  • 3502 Views
Resolved! STMCubeProgrammer will not start
I just installed en.stm32cubeprg-win64_v2-7-0.zip.Installation went without problems but when I try to start the application I get the splash screen and then it just exits apparently. If I runt it from a prompt I get no messages.C:\Program Files\STMi...
Setting Auto mode with STM32CubeProgrammer v2.7.0
I have just started using STM32CubeProgrammer v2.7.0 and I liked the simple and great looking UI over the other programmers. Now I would like to use Automatic mode and expect the following:Erase the Read Out Protection (RDP) in OB or set it to "AA"Fu...
JABRA.1 by Associate II
  • 5598 Views
  • 9 replies
FDCAN programming support?
As far as I can tell, cube programmer supports programming over CAN, but not FDCAN, like on the newest MCUs. True? Is there a path for STLink and cube programmer to support FDCAN?
MMedv by Associate II
  • 1741 Views
  • 1 replies
Announcement
We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
