STM32CubeProgrammer (MCUs)
STM32CubeProgrammer 2.18.0 released
STM32CubeProgrammer v2.18.0 release information New features:  Added the support for the STM32N6 series– OTP programming– External memory programming– Serial boot via USB/UART– FSBL signature with stm32header V2.3 through the signing tool• Added the ...
run STM32CubeProg on Raspberry pi 4
I don't see ARM 32/64 bit in the system requirements of STM32CubeProg. Is it possible to get this running on like a raspberry pi 4? I am interested in CLI onlyor do you have other suggestions on how i could do a flash of stm32 chip (STM32G070CB)
GHama.1 by Associate
  • 830 Views
  • 1 kudos
Resolved! Programming an STM32F7xx via USART1
Hello, I try to programm a STM32F765 via USART1 (PA9/PA10), but the connection fails. I use STM32CubeProgrammer v2.7.0.If I use USART3 instead on my target, programming works as expected.Q: Is there a known bug, and USART1 does not work on this CPU? ...
Can't program STM32F411CEU6 via UART interface
Hi,I'm having a very similar issue reported in this question. My problem: I can't program a STM32F411CEU6 with Arduino IDE and using UART.So, I have designed a customized board with a STM32F411CEU6. I'm new in the field and so to prevent any big surp...
MWon.1 by Associate II
  • 1612 Views
  • 3 replies
My STM32H743 MCU can not get into USB DFU mode, which has initial bootloader version 13.2 I got the wrong ic or there is another solution?
Hello ~My STM32H743 MCU can not get into USB DFU mode, which has initial bootloader version V13.2I follow the instruction, boot0 pin to high, plug usb, watching my device list, but there is no STM FS DFU device.I designed new board with stm32h743xi, ...
GLee.4 by Associate
  • 686 Views
  • 1 replies
STM32F410 EXTERNAL LOADER CREATE
Good morningI am trying to create and use SPI EXTERNAL LOADER using STM32F410 CBT3. I created EXTERNAL LOADER using S25FL032P_STM32G071B_NUCLEO sent from STM. Data is read from STM32CUBEPROGRAMMER, but data mismatch found at address 0x90000000 occurs...
GGIL.1 by Associate II
  • 450 Views
  • 1 replies
Resolved! External Loader with STM32CubeProgrammer
I created an external loader, I tried it with STM32CubeProgrammer. Most of the time its not working, rarely it can read the data and erase. When it happens I am trying to program the memory and it can program ~400 KB then it fails. Then I used ST-Li...
kb24 by Senior
  • 1247 Views
