Eclipse executable launcher is unable to locate its companion shared library
zuojaing
System versions macos 15.1.1 stm32cubemx 6.13, stm32cubeide1.17. When I generate code using cubemx and select stm32cubeide in the toolchain, an Eclipse prompt box will pop up, indicating that The Eclipse executable launcher was unable to locate its companion shared library, I have replaced several recent versions of stm32cubemx, but the problem still exists. Have you encountered similar situations? Can you provide a solution? I'm almost going crazy with my Mac
SofLit
Same issue as this thread.
PS:
1 - This is NOT an online support (https://ols.st.com) but a collaborative space.
2 - Please be polite in your reply. Otherwise, it will be reported as inappropriate and you will be permanently blacklisted from my help.
2 REPLIES 2
SofLit
PS:
Accept as Solution
