STM32CubeMX (MCUs)
STM32CubeMX 6.13.0 released
We are pleased to announce to you that the release 6.13.0 of STM32CubeMX is available. What is new in 6.13.0: Added support for the following series, microcontrollers and microprocessors: STM32N6, STM32U3, STM32WL3x, STM32G411xx and STM32C0Added the ...
UART DMA Transmit and receive not working
I'm using Atollic True Studio V 9.0 , CubeMx v5.1.0, STM32F407VG-DISC1 board and enabled DMA for UART2. My code:int main(void) { int i = 0; HAL_Init(); for(i = 0; i<10; i++) rx_arr[i] = 0; for(i = 0; i<10; i++) tx_arr[i] = i*2;   SystemCl...
Resolved! Problem: If I set RTOS task priority to value higher than osPriorityNormal causes a Hard Fault when running on STM32F47xx. Has anyone else encountered this?
I'm running CubeMX 5.1 with FW_F4 V1.24.0 and Atollic TrueStudio 9.3.0. I have eleven RTOS tasks defined in CubeMX, but only one is actually invoked with its StartTask routine. As long as the priority on the task is osPriorityNormal(0) or lower, th...
cjwilde by Associate II
  • 857 Views
  • 3 replies
Does STM32F373 work in CAN Slave mode?
I am trying to implement CAN between two STM32F373, with one as master and another as slave. The problem I am facing is that it cannot be configured in slave mode. I am using Cube MX to create the initial configuration.When I configure in slave mode ...
Resolved! TIM3 as Timebase Source on STM32F302RB
I recently switched an older project to CubeMX 5.1.0 and the F3 firmware package V1.10.0. We used freeRTOS and tim3 as the timebase source as tim1 and tim2 are already in use. The program does not pass the initial timebase configuration any more and ...
Blacbird by Associate II
  • 780 Views
  • 4 replies
Attempting to read/write to SD card via SDIO on STM32F
I'm trying to read and write to a microSD card using this reader from sparkfun https://www.sparkfun.com/products/12941 and a nucleo board with a STM32F429ZIT6U MCU via SDIO interface. I created the project through CubeMX V 4.21 (I used the most curre...
RRayb by Associate II
  • 1279 Views
  • 5 replies
