STM32CubeMX (MCUs)
Ask questions on STM32CubeMX. Discuss code generation and configuration challenges, among other topics.
STM32CubeMX 6.16.1 released
We are pleased to announce that the minor version 6.16.1 of STM32CubeMX is available. What is new in 6.16.1: This release addresses and resolves the issues outlined below: Users of STM32CubeMX version 6.13.0 and later may encounter a HardFault except...
Aimen1 by ST Employee
  • 1052 Views
  • 0 replies
  • 1 kudos
STM32CubeMX 6.16.0 released
We are pleased to announce that STM32CubeMX 6.16.0 release is available. What is new in 6.16.0: Added support for new microcontrollers across the STM32WBA, STM32N6 and STM32H5 series and the STM32WL3x product line. The related new boards include the...
  • 1831 Views
  • 5 replies
  • 7 kudos
We are running into an issue with the built in system bootloader of the STM32F413. Have issues with Soft reset
Our system communicates primarily through CAN bus, we issue a command to the micro controller and then it will reset and jump into the bootloader.From there we have implemented the protocol as described in AN3154.This looks like it is working as int...
Resolved! Overflow on timeouts in STM32 HAL driver
Every code in HAL driver has the below structure that doesn´t care about overflow on HAL_GetTick().... tickstart = HAL_GetTick();   while (Something()) { if (Timeout != HAL_MAX_DELAY) { if (((HAL_GetTick() ...
NUCLEO-F411RE: user USB support
Hi,I am using NUCLEO-F411RE for development and wondering whether I can developed user USB Device application with custom VID and PID. I tried custom hid example from STM32Cube_FW_F4_V1.24.0 SDK but seems not working, once downloaded I can see only 1...
DHinge by Associate II
  • 1351 Views
  • 1 replies
How to get STM32CubeMX to include DSP Header files?
I have searched, but I cannot find any information how to get the newer STM32CubeMX 5+ or the STM32CubeIDE to include the DSP header files arm_math.h, arm_const_structs.h, and arm_common_tables.h. They were copied on the older versions. How do I tell...
Stephen28 by Associate III
  • 7473 Views
  • 23 replies
  • 4 kudos
Hardfault error in SPI slave - polling mode
Hi, I am using cubemx to configure a stm32f411ve board as slave in receive only, polling mode and sofware NSS, in the code generated I have only added a few lines of code, only which I consider neccesary**the master sends 12 bytesoutside main functio...
OPAMP's of STM32G474 reserve not needed output pin when using internal output connection ? (probably BUG or incorrect CubeMX behavior/ no correct option).
Hello ST community,When I use OpAmp's of STM32G474 and configure all of them to internal ADC connection, all of them still reserve external output pins as analog .I'm using : OpAmp's in Inverting mode, with PGA enabled, positive input internal conne...
MMatj.1 by Associate III
  • 2130 Views
  • 8 replies
MDK-ARM project generation failed
Using the latest version 5.5 of stm32cubemx. When I try and generate a new project I get the following error after clicking generate codeThe resulting project file is unusable.I've attached the ioc file for this project.I'm presuming this is a bug th...
