STM32CubeMX (MCUs)
STM32CubeMX 6.13.0 released
We are pleased to announce to you that the release 6.13.0 of STM32CubeMX is available. What is new in 6.13.0: Added support for the following series, microcontrollers and microprocessors: STM32N6, STM32U3, STM32WL3x, STM32G411xx and STM32C0Added the ...
I have a problem in generate code in cubemx
I have a ready project that was created with cubemx 4.19, It's ok when I compile this project by keil version 5.15, but when I generate it by cubemx 5.4 I have some errors after compile it by keil version 5.15for example "undefined dword"What is the ...
alianvari by Associate III
  • 623 Views
  • 4 replies
Using .extSettings file
In the help document concerning .extSettings file the information is unclear.As I read it the Groups section is supposed to create/add directories and files.It does not. I have generated the project for SystemWorkbench and EWarm.I downloaded a test v...
STM32L433 DMA Issues - No Interrupt
Hello Community:What I am doing should be easy and straightforward, but the results are not. On this card (NUCLEO-L433) I am using CubeMX to do just one thing - set USART1 to transmit and receive, with only the receive set up for DMA. I set it up in ...
Resolved! LL_TIM_*() calls take too much time.
I am having a problem with a timer. I use CubeMX LL drivers, with basic time-base timer configuration.STM32L100RCT6, TIM6 and TIM7. Core Clock = 32MHz, PCLK1 (TIM6 and TIM7) = 32MHzPrescaller = 31, which should set timer to tick at 1us. ARR value is ...
