STM32CubeMX (MCUs)
STM32CubeMX 6.13.0 released
We are pleased to announce to you that the release 6.13.0 of STM32CubeMX is available. What is new in 6.13.0: Added support for the following series, microcontrollers and microprocessors: STM32N6, STM32U3, STM32WL3x, STM32G411xx and STM32C0Added the ...
TIM1 OPM mode waveform generation.
i want to generate above signal with variable Toff and Ton fix.i generate code but i don't get my desired out put signal./** ****************************************************************************** * File Name : TIM.c * Descript...
FOTA using STM32
According to AN2606 (STM32 microcontroller system memory boot mode), Section 4.3, we require a 'HOST' peripheral, to communicate with STM32 MCU, in order to get new firmware from the peripheral (while booting from System Memory).Flowchart from Sectio...
STM32 SPI DMA MODE
Hello, I am generating code using STM32MX CUBE. Please let me know how bust increment for peripheral and memory will affect compunction. Thanks
STM32F407 fails on HAL_RCC_OscConfig
Hello guys,I got a "STM32F407-DISC1" board and if I configure the external oscillator, it goes into "error_handling:RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;   RCC_OscInitStruct.HSEState = RCC_HSE_ON;   RCC_OscInitStruct.PLL.PLLS...
JBlaz.1 by Associate II
  • 8131 Views
  • 11 replies
Resolved! A bug of STM32G4xx LL library
I reporte a bug of STM32G4xx LL library, the Definition of DMAMUX_LL_EC_REQUEST Transfer request in header file "stm32g4xx_ll_dmamux.h" as shown below.#define LL_DMAMUX_REQ_FMAC_WRITE     0x0000006EU /*!< DMAMUX FMAC WRITE request */#define LL_DMAMUX...
PSui.1 by Associate II
  • 1283 Views
  • 9 replies
Resolved! Overflow on timeouts in STM32 HAL driver
Every code in HAL driver has the below structure that doesn´t care about overflow on HAL_GetTick().... tickstart = HAL_GetTick();   while (Something()) { if (Timeout != HAL_MAX_DELAY) { if (((HAL_GetTick() ...
NUCLEO-F411RE: user USB support
Hi,I am using NUCLEO-F411RE for development and wondering whether I can developed user USB Device application with custom VID and PID. I tried custom hid example from STM32Cube_FW_F4_V1.24.0 SDK but seems not working, once downloaded I can see only 1...
DHinge by Associate II
  • 707 Views
  • 1 replies
