STM32CubeMX (MCUs)
STM32CubeMX 6.14.1 released
We are pleased to announce that the minor version 6.14.1 of STM32CubeMX is available. What is new in 6.14.1: SAI settings not displayed in the configuration tab of STM32H7Bxxx devices: After upgrading to STM32CubeMX 6.14.0, the SAI tab configuration ...
STM32CubeMX 6.14.0 released
We are pleased to announce that the release 6.14.0 of STM32CubeMX is available. What is new in 6.14.0: Added the support for the STM32WBA6xxx microcontrollers and:Added the support for USBX multi-instanceAdded the support for the memory management to...
STM32F756 Ethernet and lwIP Rx and Tx Descriptor
Hello,I am creating a new project using STM32CubeIDE to use lwIP with internal MAC for a Nucleo F756 Board. When I enable the Eth peripheral, I can configure the Rx and Tx descriptors. They are placed at the start of SRAM2 (0x2004C000).Since the Cube...
HAL RTC SetDate Bug or some another way to do??
Posted on February 23, 2017 at 10:49I am using STM32F103 in my new application. I have used STM32Cube to generate my code including Internal RTC. Myproblem is that the time is ok saved when reseted but date is always reset. when i inspected the code...
Output Compare Register update in stm32
I had taken TIM1 asn Master to Trigger TIM8 here below i had attached the timer configuration Clock Frequency 480mhz ,timer clock 240mhzHere Iam Triggering The TIM8 after 2.5us started from TIM1 both are 100khz frequency in TIM->CCR3 register iam loa...
STM32CubeMX: TSC Advice
Well I got the new board back it seems to work, but it's quite different: I have 3 groups of 3 sensors and one group used for the shield. Previously Cube MX defined this as 3 Banks, now it has defined 6 Banks. Should I worry about this? In the first ...
Lanceh by Associate II
  • 326 Views
  • 3 replies
