STM32CubeMX (MCUs)
STM32CubeMX 6.13.0 released
We are pleased to announce to you that the release 6.13.0 of STM32CubeMX is available. What is new in 6.13.0: Added support for the following series, microcontrollers and microprocessors: STM32N6, STM32U3, STM32WL3x, STM32G411xx and STM32C0Added the ...
How to update only HAL usart drivers in my program ?
I have used stm32cubemx v5.2 to create my project .Now i want to update only Uart drivers to drivers of cubemx V6.3 (latest drivers)How to do it ?Is it safe to just replace ?stm32l0xx_hal_uart.c and stm32l0xx_hal_uart.h with newer drivers ?
SA.17 by Associate III
  • 496 Views
CubeMX LwIP initial Ip problem
Hi, I kindly need your help. I have a STM32F769 and TCP server application . I am using LWIP stack . In my application server is arm and PC is client. When client tries to send something to arm, arm binds client’s ip address. So the connection is ok ...
nur by Associate II
  • 696 Views
  • 4 replies
Resolved! STM32CubeMX 6.3.0 BUG?
main.c generated by STM32CubeMX 6.3.0Line 23#include "usb_device.h"#include "usb_device.h" Are duplicated.Then MX_RTC_Init () is missing HAL_RTCEx_SetWakeUpTimer_IT ().
tsuna by Associate II
  • 494 Views
  • 1 replies
Good starting point for VCP module (FT232 replacement)
I just ordered a PCBA with FT232RL as USB-VCP bridge and found that these things are bulky, expensive and out of stock mostly. So why not design a USB-serial (eg. 3.3 V 9600 bd) bridge using any STM32?I am aware that CubeMX supports USB/VCP so this i...
MMMartin by Associate II
  • 818 Views
  • 5 replies
Devicetree generation for MCU
Hi,Zephyr OS use device tree to describe hardware layer on MCU. Is there anyway I can generate device tree from STM32cubeMX configuration (ioc file) as we can do it for MPU ? Thanks,
FLapo.2 by Associate
  • 383 Views
  • 0 replies
  • 1 kudos
