STM32CubeMX (MCUs)
STM32CubeMX 6.13.0 released
We are pleased to announce to you that the release 6.13.0 of STM32CubeMX is available. What is new in 6.13.0: Added support for the following series, microcontrollers and microprocessors: STM32N6, STM32U3, STM32WL3x, STM32G411xx and STM32C0Added the ...
Resolved! STM32CubeIDE/MX with freeRTOS
I am using STM32CubeIDE to build a freeRTOS project. I have put my tasks in their own .h and .c files. For example I have a default_task.c file. The problem is each time I open CubeMX and save my changes, the 'auto code update' feature does not se...
LMorr.3 by Senior II
  • 2639 Views
  • 3 replies
Undefined reference to api's in new custom folder
Hi,I have created project using the STM32CubeIDE with .ioc. And added new folder for application code. Problem statement: Any API defined in my application file which under the Application folder will not identified by the Core files.I have defined t...
Resolved! In STM32CubeMX, when configuring the STM32H750VB MPU with more than 1 memory region and Generating Code, CubeMX gives a warning that some settings in the CORTEX_M7 module are missing or incorrect. I believe this is incorrect. Is this a bug in CubeMX?
I am trying to configure the Internal Flash (0x08000000, 128KB, cacheable), DTCM RAM (0x20000000, 128KB, non-cacheable), AXI SRAM (0x24000000, 512KB, cacheable), and QSPI (0x90000000, 4MB, cacheable).There is no indication of what parameters might be...
DPade.1 by Associate III
  • 1489 Views
  • 3 replies
Resolved! [H723] I want to know why it becomes a hard fault
H723ZGT6 Nucleo-144CubeMX 6.3.0AN209, Summer 2017, V 5.0An error occurred when writing a for loop process before SDRAM initialization.I know the solution, but I don't know why this is happening.(Add static or volatile or write a for loop after SDRAM ...
june by Associate III
  • 1281 Views
