STM32CubeMX (MCUs)
Ask questions on STM32CubeMX. Discuss code generation and configuration challenges, among other topics.
STM32CubeMX 6.16.1 released
We are pleased to announce that the minor version 6.16.1 of STM32CubeMX is available. What is new in 6.16.1: This release addresses and resolves the issues outlined below: Users of STM32CubeMX version 6.13.0 and later may encounter a HardFault except...
Aimen1 by ST Employee
  • 1023 Views
  • 0 replies
  • 1 kudos
STM32CubeMX 6.16.0 released
We are pleased to announce that STM32CubeMX 6.16.0 release is available. What is new in 6.16.0: Added support for new microcontrollers across the STM32WBA, STM32N6 and STM32H5 series and the STM32WL3x product line. The related new boards include the...
  • 1809 Views
  • 5 replies
  • 7 kudos
IAP with Ymodem has an error when first send the file.
Like subject when I powered on my mcu board and sent '.bin' file first, it occured an error "The image size is higher than the allowed space memory".But Sent same '.bin' file again, it's OK.I used to STM32F429ZI, IAR Compiler and  Menu.c & .h , commo...
UTU by Associate
  • 924 Views
  • 1 replies
Resolved! Cube MX custom template for custom folder structure
The STM32CubeMX User Manual (UM1718 section 3) and various threads on this forum lead me to believe I can customize the folder structure that CubeMX uses for where it puts the code files it generates. I'm not trying to do anything fancy, I'd just lik...
magene by Senior II
  • 2316 Views
  • 1 replies
Non-secure interrupts are not working with trustzone enabled
CubeMX generates a file called "partition_stm32h563xx.h", this file contains the settings of which interrupts are available in the non-secure area, when trustzone is enabled.For stm32h563 the generated list of interrupts is wrong.There are many inter...
Mogens by Associate
  • 1066 Views
  • 1 replies
Resolved! Generated HAL Timer Tick generated code has an error - F7
I am using STM32CubeIDE 1.13.2 with STM32CubeMX 6.9.2-RC4.  It is an STM32F746 processor.  I'm using STM32Cube_FW_F7_V1.17.1 libraries.  I'm using Azure RTOS and selected TIM12 for the HAL tick time base.This is a side issue.  When TIM12 was selected...
tec683 by Associate III
  • 2310 Views
  • 1 replies
Resolved! MX_SDIO_SD_Init wrong bus wide initialization
I have a STM32F407 with an SD card wired in 4-bytes mode and FATFS middleware to manage the files.I upgraded to STM32CubeIDE 1.11 two weeks ago, but since then the SD card stopped working. The initialization fails in the SD_WideBus_Enable function, s...
FRugi.1 by Associate
  • 3985 Views
  • 3 replies
  • 1 kudos
