STM32CubeMX (MCUs)
STM32CubeMX 6.13.0 released
We are pleased to announce to you that the release 6.13.0 of STM32CubeMX is available. What is new in 6.13.0: Added support for the following series, microcontrollers and microprocessors: STM32N6, STM32U3, STM32WL3x, STM32G411xx and STM32C0Added the ...
mbedTLS with support of TLS_1.3 in STM32CubeMX
Hi,I'm using the STM32H753I-EVAL2 (MCU Type: STM32H753XIHX) to develop a new product.The product will communicate to server using the LwIP (TCP Layer) + MbedTLS (SSL/TLS Layer), running over FreeRTOS environment.We want to use the latest TLS protocol...
APilai by Associate
  • 2266 Views
  • 1 kudos
Resolved! Trouble configuring I2C pins in CubeMx
Can someone please explain to me how this is even possible on the same device? They are the exact same device yet I can not seem to get the same pin config in different projects.The one project somehow got the PIN Layout where PB6(SCL) and PB7(SDA)...
table by Associate II
  • 219 Views
  • 1 replies
  • 1 kudos
STM32G0 minimum ADC frequency
I'm configuring an STM32G031, using the STM32CubeMX perspective in STM32CubeIDE.  I want to optimise for low power consumption.  My device uses the ADC and I see the ADC has a minimum acceptable frequency, 140kHz according to the data sheet (data she...
GrahamAU by Associate II
  • 256 Views
Simulink error for programming ST Nucleo board
Hi,I want to program my STM32H753ZI Nucleo board with Simulink. I successfully programmed it to blink an LED. However, I get the following error when I try to enable a timer (for PWM, or Encoder). C:/ProgramData/MATLAB/SupportPackages/R2023b/toolbox/...
hsafamehr by Associate II
  • 1365 Views
  • 5 replies
  • 4 kudos
Resolved! CubeMX bug when configurating ADC for stm32u031
Hello,I get error messages in Cube MX trying to configure the ADC in STM32U031F6Px to Not Fully Configurable.To reproduce:Start a new project, choose STM32U031F6P6 as MCUGo to ADC, check any channel (e.g. temperature)Change sequencer to "sequencer se...
