STM32CubeMX (MCUs)
STM32CubeMX 6.13.0 released
We are pleased to announce to you that the release 6.13.0 of STM32CubeMX is available. What is new in 6.13.0: Added support for the following series, microcontrollers and microprocessors: STM32N6, STM32U3, STM32WL3x, STM32G411xx and STM32C0Added the ...
Help setting up comparator on STM32G0B1
Hello,New to this forum and quite new to STM32 platform, so hi to the community! I have trouble setting up comparator on board nucleo-stm32G0b1RE. I've been following some tutorials on how to setup through stm32CubeMx, I believe I have the settings r...
Kemsa by Associate
  • 172 Views
  • 1 replies
Resolved! STM32CubeIDE while(1) bug? Linux versions
Hello, I see in code generated by all Linux versions of CubeIDE that USER CODE BEGIN and USER CODE END tags in infinite loop, are not in the better place.Code generated by Cude IDE: /* Infinite loop */ /* USER CODE BEGIN WHILE */ while (1) { ...
xisco by Associate III
  • 282 Views
  • 3 replies
  • 2 kudos
Resolved! SMPS Configuration
Using STM32CubeMX Version 6.11.1 for code generation of STM32U545RETxQ LQFP64.When pressing "Generate Code" there is a message recommending SMPS setting from the PWR menu.However, no SMPS there and not anywhere in the configuration menu. (Attached)An...
IP.2 by Associate II
  • 295 Views
  • 1 replies
Resolved! Fail to find a clock
Hello there,I’m trying to squeeze functionality into an STM32U5 MCU via the STM32CubeMX tool.After setting the pins, the clock configuration fails to find a solution.The requirements for the clock are to run from an internal source, as the design is ...
  • 228 Views
Resolved! Does CubeMX's .exe file include virus?
Hi,I did setup CubeMX latest(6.13) and previous version , Kaspersky have seen virus and I ignored it. After that I got some malfunction on my pc like internet connection disabled, windows bar doesnt work.
Zek_De by Senior
  • 522 Views
  • 8 replies
  • 3 kudos
Resolved! STM32CubeMX/Simulink Compatability
Good Morning, I'm using Simulink to develop code for the STM32F767 MCU, however we're looking at moving to a newer micro (STM32H7R318T6). This MCU doesn't seem to be available in STM32CubeMX V6.4.0, which is the officially supported version, so I hav...
Resolved! FLASH.ld syntax error when upgrading to CubeMX v6.12.1
Hello,Since the latest release of CubeMX (6.12.1), I have been encountering syntax errors related to the "FLASH.ld" file. This issue only arises when I generate code while setting the Toolchain/IDE to CMake. I am using STM32H753IIKx. It seems that Cu...
OmidES by Associate II
  • 12778 Views
  • 45 replies
  • 55 kudos
