STM32CubeMX (MCUs)
STM32CubeMX 6.13.0 released
We are pleased to announce to you that the release 6.13.0 of STM32CubeMX is available. What is new in 6.13.0: Added support for the following series, microcontrollers and microprocessors: STM32N6, STM32U3, STM32WL3x, STM32G411xx and STM32C0Added the ...
Why I don't have MX_X_CUBE_AI_Init
Hi,I've successfully generated a project with X-CUBE-AI. I searched for some examples on the internet and I've found that MX_X_CUBE_AI_Init is missing from my project. Why this function call is missing? I've the latest CubeMX.
Test User by Associate III
  • 782 Views
Porting X-CUBE-TIMCOOKER from F302R8 to F401RE
I want to port the TIMCOOKER examples from STM32F302R8 to STM32F401RE. This is easily done according to the data-brief, as the examples are generated using CubeMX. However, there are no .ioc files present in the repository so I guess you need to chan...
CubeMX, reports, .ioc file format, diff / tooling
a) looking at UM1718 Rev 41 (July 2023) "11.4 Generating the report" there should be a button in the "Project Manager" Tab to start a export. I don't remember seeing it before and in "STM32CubeMX - STM32 Device Configuration Tool Version: 6.9.0-RC9 B...
_richard by Associate III
  • 2301 Views
  • 5 replies
  • 1 kudos
RCC config problem
Hi,Latest CubeMX.Steps to reproduce RCC config error1. Board:STM32H747I-DISCO2. Click on X-CUBE-AI, select Cortex-CM7, select Install for X-CUBE-AI/Core, press OK3. Project manager: set project name, toolchain: CubeIDE, generate the code4. Click agai...
  • 884 Views
Resolved! Install fails on step 8/9 'C:\Program' is not recognized
I have been trying to install STM32CubeMX (SetupSTM32CubeMX-6.9.1-Win.exe) for a *while* and yes I right-clicked and chose "Run as Administrator". It always fails during step 8/9 with the same message that "'C:\Program' is not recognized as an intern...
TonyM by Associate II
  • 6014 Views
Changing SystemClock in XiP
Hello,I'm currently working with the STM32H750 and using a bootloader that runs a basic Clock and QUAD SPI Config for XiP and jumps to the main application.Once in the main application, a new clock config is applied using the generated SystemClock_Co...
rmartins by Associate II
  • 1274 Views
  • 5 replies
CubeMX HRTimer config bug
HelloI found bug in BurstMode Configuration in HRTimer. There is not possible to set Burst Mode Period lower than DeadTime. It is OK, but CubeMX compare numbers only and does not count with prescalers values. I think Burst mode period must be grater ...
PDvor.2 by Associate
  • 733 Views
Resolved! STM32CubeMX I2C on STM32H563
Hi,I use STM32CubeMx 6.9.1 on a STM32H563 project. Programming the I2C pins, there is no way to setup the I2C_SCL pin as Alternate PushPull. Only the Alternate Open Drain is possible. Why?In my application, the I2C_SCL pin is connected to a serial EE...
Ez by Associate II
  • 1530 Views
  • 4 replies
