STM32CubeMX (MCUs)
STM32CubeMX 6.14.0 released
We are pleased to announce that the release 6.14.0 of STM32CubeMX is available. What is new in 6.14.0: Added the support for the STM32WBA6xxx microcontrollers and:Added the support for USBX multi-instanceAdded the support for the memory management to...
Resolved! STM32F103: Option to assign pins to core M3 in CubeMX
Hello,When generating code via CubeMX, the main code does not contain the configuration for the GPIO pins I need to be using.I have checked other solutions and seen that the pins need to be assigned to the core (in this case it would be the M3). The ...
XPChi by Associate II
  • 229 Views
  • 6 replies
  • 1 kudos
Resolved! [STM32H7] How to use SDMMC with MDMA
Hello Community,I'm working on a storage module using SDcard for my project. In my application I would like to read and write to the SDcard using the MDMA as indicated in the reference manual of my micro-controller. For now I have the SDcard working ...
MVerr.1 by Associate
  • 5009 Views
  • 11 replies
  • 6 kudos
Resolved! Can't Change GPIO Pull-up/Pull-down Mode for a Timer
I have a STM32F469I-DISCO board. It seems that I am unable to change the GPIO Pull-up/Pull-down Mode for a timer. I have tried to do it both in the CubeMX interface, and I have also looked through the HAL methods and attributes. I don't think it's an...
Resolved! SMPS on the STM32H747XI
I have created a project for the STM32H747I-DISCO and have deadlocked the MCU twice. a BIG thanks to ST for not having ANY warning about this. The DISCO board comes configured to default to SMPS mode. The project I created, without any warnings, defa...
NUCLEO-C071RB Interrupt problem
I tried this board but i get some problem about interrupt.I "writed" only 1 function ( void EXTI0_1_IRQHandler(void) ) the other code has been autmaticaley generate from Cube.The goal is : for any change of state of PA0, pulse_count++.The problem is ...
