STM32CubeIDE (MCUs)
STM32CubeIDE 1.17.0 released
We are pleased to announce to you that the release 1.17.0 of STM32CubeIDE is available. What is new in 1.17.0: Microcontrollers, microprocessors, and board lists aligned with STM32CubeMX: Added the support for the STM32N6 seriesAdded the support for ...
Resolved! Bad code generation with ADC LL API and STM32CubeIDE
I recently changed the configuration of working product from HAL API to LL API to improve performances.Unfortunately, the LL initialisation code generated by the STM32CubeIDE for the ADC was incomplete, and forgets to set the PCSEL register when need...
cberg.1 by Associate II
  • 760 Views
  • 3 replies
Resolved! STM32F1 with EasyCAT
Hello~I am testing my stm32f103rb board with ethercat board(as shown). The trouble i am having is that there is no easycat library to use. I did some research and only found the .cpp easycat library. I'm using stm32ide and written in C language. This...
ANHTUAN by Associate
  • 550 Views
  • 1 kudos
STM32CubeIDE locks up on Java
HiI have STM32CubeIDE 1.16.0 installed on Ubuntu 22.04.4 on a DELL with Intel i7. Whenever I close the IDE with the MX interface open, it cannot start again, and it complains about Java. It is probably an Eclipse error, but it is a bit of a pain. I k...
ErikLea by Associate
  • 299 Views
  • 0 replies
Compile problems because of linked resources
I update to V1.16 and found, that my project cannot compile anymore.Problem are compile errors, double definitions and so on. I did not change the code, just updated and regenerated everything include the code generation of CubeMX ( from within the i...
SThie.1 by Associate II
  • 379 Views
  • 1 replies
STMCube32 IDE - license terms not readable
When installing for example the Nx_MQTT example for B-U585IOT02A you need accept a license for CubeFW U5 1.6.0. You are supposed to view it 1st. However, at least with Ubuntu 22.04 and FireFox as default browser (default for Ubuntu 22.04) you can't v...
