STM32CubeIDE (MCUs)
STM32CubeIDE 1.17.0 released
We are pleased to announce to you that the release 1.17.0 of STM32CubeIDE is available. What is new in 1.17.0: Microcontrollers, microprocessors, and board lists aligned with STM32CubeMX: Added the support for the STM32N6 seriesAdded the support for ...
How to debug local C/C++ application using STM32CubeIDE?
Using STM32CubeIDE version 1.0.2, I can create a "local C/C++ application", in this case, "hello world" that simply prints to the console, and it will create the proper file structure and compile a working x86 executable. I can execute this program ...
dale by Associate III
  • 1379 Views
  • 1 replies
CPU freezing when inserting or removing a breakpoint
Hi,I've come across an issue whereby inserting or removing a breakpoint anywhere in my code when the processor is running causes execution to pause for ~180ms. I thought manipulation of breakpoint registers was independent of processsor execution sta...
dave2012 by Associate III
  • 354 Views
  • 3 replies
How duplicate STM32CubeIDE project for motor control
Hi, I'm new to STM32 Tools and am using a Nucleo-F302R8 and IHM07M1 motor board. I created a STM32CubeIDE project selecting these boards and importing the code. When I compile the code I was getting files not found. I located these files on my C:\ d...
BTrem.1 by Senior II
  • 281 Views
  • 0 replies
Debug bootloader and application
I am trying to create a custom bootloader and having trouble debugging where in the application it jumps to.Both projects are in the IDE.If needed. The MCU I use is a STM32F103RET6
AKoek.1 by Associate
  • 859 Views
  • 3 replies
STM IDE: missing CMSIS files
Hi, i have a problem with STM IDE projects. When i create a new project, in some cases there are no CMSIS files importet by the IDE.For example, i have crated a project with the STM32L152RCT- MCU. In the folder "Drivers -> CMSIS" are two subfolders n...
JLuck.1 by Associate
  • 868 Views
ROM/Flash Self-Test - How to implement CRC with STM32CubeIDE?
I found some guidelines on how to implement the self test on some other compilers, but I found nothing explaining how to do it for STM32CubeIDE.How to perform this test using STM32CubeIDE? ---->>>> Please do not comment on partial instructions or com...
by Not applicable
  • 824 Views
  • 3 replies
  • 1 kudos
Should I set gcc in CubdIDE ?
I want to bink a led on NUCLEO-G474RE, I used CubeMX and CudeIDE.Since I don' t want to use IAR or Keil, so I select CubeIDE toolchain in CudeMX.The code generated and has been opened as project in CubeDE, and the two lines has been added in main(): ...
MQi.1 by Senior II
  • 1826 Views
  • 18 replies
