STM32CubeIDE (MCUs)
STM32CubeIDE 2.1.1 released
We are pleased to announce that the minor version 2.1.1 of STM32CubeIDE is available. What is new in 2.1.1: This release covers the topics listed below: SEGGER J-Link GDB server updated to 9.24 to fix an issue with the Live Expression view during the...
Aimen1 by ST Employee
  • 1142 Views
  • 0 replies
  • 1 kudos
STM32CubeCLT 1.21.0 released
We are pleased to announce that STM32CubeCLT 1.21.0 release is available. What is new in 1.21.0: Maintenance of the previous version: Updated in accordance with STM32CubeIDE v2.1.0Update of Clang/LLVM toolchainUpdate of GCC to GCC 14Update of STM32Cu...
  • 487 Views
  • 0 replies
Resolved! How do I get GDB debug output to a file?
I'm debugging a problem on the target. The data I want to examine is in an array and can be easily seen in the Debugger console using "print output_data". I'd like this in a file to facilitate further host processing. When using gdb standalone I c...
SMoor.6 by Associate
  • 4655 Views
  • 1 kudos
Resolved! How can I know where a function is being used in STM32CubeIDE?
When I analyze a code that another guy made, I want to track where a function is used.I can see the definition of a function using open declaration but I cannot see where the function is used.STM32 has so many files. So, I cannot search for each of t...
KKIM.6 by Senior II
  • 4830 Views
  • 3 replies
(STM32F105C8, STM32CubeIDE 1.9.0, MacOS 11.6.5) Using STM32CubeIDE, how do I can't get TIM3 to tick/count when TIM2 overflows. (TIM2 does count up)
TIM2:Clock source: InternalMaster/Slave Mode: Disabled (Trigger input not delayed)Trigger Event Selection: Update EventTIM3:Slave Mode: Trigger ModeTrigger Source: ITR1TIM2 counts up like it should, but TIM3 doesn't count the over flow, but has incre...
FMoto.1 by Associate
  • 1614 Views
  • 1 kudos
Resolved! Failed to list external Loader
I try to add external loader to C:\ST\STM32CubeIDE_1.8.0\STM32CubeIDE\plugins\com.st.stm32cube.ide.mcu.externaltools.cubeprogrammer.win32_2.0.100.202110141430\tools\bin\ExternalLoaderIn debug configuration, check ExternalLodaer and than press Scan.Th...
ALomb.1 by Associate III
  • 8428 Views
  • 20 replies
