STM32CubeIDE (MCUs)
STM32CubeIDE 1.18.0 released
We are pleased to announce that the release 1.18.0 of STM32CubeIDE is available. What is new in 1.18.0: Microcontrollers, microprocessors, and board lists aligned with STM32CubeMX 6.14.0: Added the support for STM32WBA6xxx microcontrollers in the STM...
Resolved! Timeout downloading software packages
When trying to create a new project with the NUCLEO-G474RE board I regularly get the error in the attached image. The project then consists of only the .ioc file and Cube crashes when trying to generate code.Note that I have no issues creating a proj...
Matt1234 by Associate II
  • 1656 Views
  • 4 replies
Resolved! How to set up a breakpoint monitoring an address?
Hey all,I'm trying to verify register values in my project, as per this link: https://www.freertos.org/Debugging-Hard-Faults-On-Cortex-M-Microcontrollers.htmlI'm attempting to open the break point window in the debugger, and manually define an execut...
QHa.1 by Associate
  • 2753 Views
  • 1 kudos
Resolved! Is there a way to setup configMAX_SYSCALL_INTERRUPT_PRIORITY in freeRTOS on a STM32G0 ? It seems that this config is not available in STM32Cube Environnement and in freeRTOS port code
I am starting a new project on STM32G070KB and I want to use freeRTOS.Problem that I have is that the configMAX_SYSCALL_INTERRUPT_PRIORITY seems to be gone from the port !I use the latest STM32CubeIDE with the 1.4.1 firmware package for STM32G070KBPr...
WGend.15 by Associate II
  • 1713 Views
  • 3 replies
  • 1 kudos
Resolved! STM32CubeIDE 1.6.1 inactive code bug
Not sure where to report this.I have recently upgraded to OSX Big Sur and also to STM32CubeIDE 1.6.1Not sure when this issue started, I'm pretty sure it wasn't a problem before, and it does NOT happen on my Eclipse 2020-06 installation.Restarted, reb...
JHans.6 by Associate II
  • 1910 Views
  • 6 replies
Code changes not being used in debug mode
Hi all, I am very new to this software so hopefully this is a silly question that is easily answered.I keep running into an issue where I can make a change in the editor, build the project and then look at the code step by step in debug mode, however...
RMyer.1 by Associate III
  • 697 Views
  • 4 replies
