STM32CubeIDE (MCUs)
STM32CubeIDE 1.17.0 released
We are pleased to announce to you that the release 1.17.0 of STM32CubeIDE is available. What is new in 1.17.0: Microcontrollers, microprocessors, and board lists aligned with STM32CubeMX: Added the support for the STM32N6 seriesAdded the support for ...
Instabilities are occurring in Version 1.6.1
I'm using version 1.6.1 in linux, and there are several problems, for example, the main.c file opens but I can't use Delete or BackSpace keys, other times I can't edit the properties of the Device Configuration Tool. It has also occurred that the Dev...
by Not applicable
  • 312 Views
  • 1 replies
STM32CubeIDE 1.6.1 Update Fails on WIndows 7
I have gotten update notices for STM32CubeIDE 1.6.1 for a couple weeks now. But every time I try to update it fails. I did try deleting the cache directory "STM32CubeIDE\STM32CubeIDE\p2\org.eclipse.equinox.p2.repository\cache" but that did not work...
Resolved! No binary or hex file output
Hello,I've a strange problem with CubeIDE 1.6.0, there's no binary or hex file output even if the corresponding outputs are activated under MCU post build outputs. Any ideas what might be the issue there?Regards
RAltm by Senior
  • 4350 Views
  • 20 replies
  • 1 kudos
After upgrading to STM32CubeIDE 1.6.1 the .cproject file gets messed up with spaces instead of tabs and extra blank lines (spaces + tabs) between each normal line. This messes up any source control system.
prior 1.6.1:<?xml version="1.0" encoding="UTF-8" standalone="no"?> <?fileVersion 4.0.0?><cproject storage_type_id="org.eclipse.cdt.core.XmlProjectDescriptionStorage"> \t <storageModule moduleId="org.eclipse.cdt.core.settings"> \t \t <cconfiguration i...
Martin_S by Associate II
  • 418 Views
  • 1 replies
  • 1 kudos
LWIP HTTP Server. Packets retransmittion.
Hello, dear colleagues!I'm trying to build http server based on LWIP on Nucleo F429 board. An example from Cube repository works fine, also with my custom http data and paths, which I have included in example project. But, another CubeIDE generated p...
How to disable error popup window.
Hello!I'm using STM32CubeIDE 1.6.1. This question is not specific to 1.6.1, the problem (or feature???) existed before.When debugging (build and debug, or press the green bug), if there are errors, the IDE asks me if I want to run (proceed with launc...
PG.1 by Associate III
  • 641 Views
STM32CUBEIDE DEBUG PROBLEM
HelloMy debugger is shutting down after downloading code into chip I can connect STLINK UTILITY and uploading code hex files properlySTMicroelectronics ST-LINK GDB server. Version 5.8.0 Copyright (c) 2020, STMicroelectronics. All rights reserved.   S...
Proteus by Associate II
  • 383 Views
  • 1 replies
