STM32CubeIDE (MCUs)
STM32CubeIDE 1.17.0 released
We are pleased to announce to you that the release 1.17.0 of STM32CubeIDE is available. What is new in 1.17.0: Microcontrollers, microprocessors, and board lists aligned with STM32CubeMX: Added the support for the STM32N6 seriesAdded the support for ...
After successfully added a second project to the workspace as static st32 library, I would like to know ho consume this library from the main project. From Path and Symbols I added the library ${workspace_loc:/ModuleA/Debug/libModuleA.a}.
What else should I do to let my project see header files? Is it correct to add an include path suchC:\Progetti\STM_Projects\ModuleA\Base. But I would like that it sees all the files and possible without an absolute path? What is the correct syntax?Be...
FMarr.2 by Associate III
  • 262 Views
  • 1 replies
Resolved! #include <string> into cpp header file
Hello everyone, I have a problem with include string methods into cpp header file. I created .cpp files like in this example: https://dev.to/younup/cmake-on-stm32-episode-5-get-ready-for-c-1mh9Also, I generated the project with c++ checkbox.When I #i...
JuniorSTM by Associate II
  • 8456 Views
  • 6 replies
protected files change
I use cubeIDE 1.5.1. I download standart example BLE_HeartRateFreeRTOS. It has got file app_conf.h In cubeIDE it has got strange icon. In app_conf.h I change CFG_LED_SUPPORTED to 1 and save. Clean and Build. But app_entry.c still thinks that define i...
Resolved! undefined reference to
Hello!Can somebody say what im doing wrongI have project in STM32CubeIDE with lwip and freertosIm trying to add new thread(as new task) with exist principles and cant do it/* Definitions for TCPip */osThreadId_t mtcpConHandle;const osThreadAttr_t mtc...
Agde.1 by Associate III
  • 2108 Views
  • 9 replies
Resolved! Distribuited compilation.
Hi,due to size of project, i would like to know if there is some plugin to distribuite compilation over more cores like Incredibuild does on visual studio or is it possible, meaning it is supported to develop for stm32 under visual studio.Even other ...
  • 542 Views
  • 1 kudos
Resolved! How to use STM32F407 FSMC memory ?
Hi,I'm working in a project that contains large data need to be processed by using stm32f407 Disc1. I facing issue with RAM overflow so, I need to use external ram by using FSMC.what is the large size of external ram that I can use it? , Is this exte...
MHass.2 by Associate III
  • 928 Views
  • 1 replies
