STM32CubeIDE (MCUs)
STM32CubeIDE 1.17.0 released
We are pleased to announce to you that the release 1.17.0 of STM32CubeIDE is available. What is new in 1.17.0: Microcontrollers, microprocessors, and board lists aligned with STM32CubeMX: Added the support for the STM32N6 seriesAdded the support for ...
How to make LwIP work with CMSIS_V2 in CubeIDE?
Hi,I have a Nucleo-F439ZI board and I am trying to make a simple application that echoes back a message on a UDP port.When I generate a project using LwIP raw API, I am able to make that happen with a callback function and a PCB.However, as soon as I...
GFeke.1 by Associate
  • 693 Views
  • 1 replies
Resolved! STM32F746G-DISCO, STM32CubeIDE
I want to write to FLASH and read. Why doesn't it record?HAL_FLASH_Unlock(); FLASH_Erase_Sector(FLASH_SECTOR_7, VOLTAGE_RANGE_3); HAL_FLASH_Program(FLASH_TYPEPROGRAM_WORD, FLASH_SECTOR_7, 300); HAL_FLASH_Lock(); set_time = *(__uint32_t*) FLASH_SECTOR...
Cannot install stm32cube_fw_f4_v1261.zip Error downloading files: (Target directory already exists). Multi year stm32cube bug is still not fixed. Updated previously documented workaround method for this particular firmware update. ARG!
This error message is false since the zip file downloads but errors during extraction.The folder inside stm32cube_fw_f4_v1261.zip is STM32Cube_FW_F4_V1.26.0 which I had already manually installed.So I guessed and changed the subfolder name for v1261 ...
Question about overclocking STM32F411 in STM32CubeIDE
Hello I am working on a one off project that I would like to squeeze every last bit of power out of a STM32F411. I tried to overclock it just by increasing the clock speeds in the clock configuration section of cubeIDE but it always crashes when I tr...
CStew.2 by Associate II
  • 1637 Views
  • 9 replies
