STM32CubeIDE (MCUs)
STM32CubeIDE 1.17.0 released
We are pleased to announce to you that the release 1.17.0 of STM32CubeIDE is available. What is new in 1.17.0: Microcontrollers, microprocessors, and board lists aligned with STM32CubeMX: Added the support for the STM32N6 seriesAdded the support for ...
STM32CubeIDE and cluster support in the SFR panel view
Hello,I'm updating the STM32G0B1.svd file with the FDCAN RAM message registers because right now they are missing. Since it is a lot of registers arrays and clusters, I was willing to use those keywords in the svd file. However, when trying to debug,...
Kraal by Senior III
  • 673 Views
  • 1 replies
Building .bin file CubeIDE
My CubeIDE project currently builds a debug .elf and I am trying to build a .bin file instead. In order to do this, I researched the forums that say I need to go to project properties: C/C++ Bulild->Settings->Tool Settings->MCU Post Build outputs and...
RKher.1 by Associate III
  • 1718 Views
  • 1 replies
Import from Keil MDK into STMCubeIDE
Hello,I have been trying to import an already-existing project into CubeIDE. This project was created on Keil MDK. So, when I import the project, CubeIDE does not recognize the drivers for the board I am program, nor the source files. How can I use t...
BRodr.3 by Associate III
  • 9680 Views
  • 27 replies
  • 1 kudos
How to debug STM32IDE?
Hi. i'm beginner this field and researching for UWB system. so i bought the decawave product to get channel impulse response raw data.​Decawave provides an example, and the example is executed on stm32cubeide. so i installed some software and use the...
HJung.3 by Associate II
  • 451 Views
  • 1 replies
Resolved! Kernel not starting
Hi all,I am pretty new to the STM32 world and I have just started to play around with the STM32F429 discovery kit and STM32CubeIDE. I am OK with the basic & introductory projects, and I was able to have basic IO operations like LED blinking run prope...
DK.9 by Associate II
  • 3260 Views
  • 7 replies
Is it possible to import Makefile in STM32CubeIDE?
I have a C project which is developed outside of STM32Cube IDE. The project contains Makefile.It will be very good to just import the entire project in STM32Cube IDE and compile using the existing Makefile as a part of a bigger project which is alrea...
MDrob.1 by Associate
  • 1052 Views
  • 1 replies
Semihosting on RUN mode
Hello,I have enabled the semihosting.The semihosting is running on the debug mode properly.And debug message by printf() is displayed on the console window of the cubeide.But if the project is ran on the run mode(run, not debug), my code is not proce...
Kim.Andy by Associate III
  • 2022 Views
  • 4 replies
Interrupts not working when using openOCD cubeIDE
I’m using cubeIDE and openOCD to debug on stm32f103. The interrupts not called although the interrupt flags are set. I tried to use GDB and they works fine for the same SW on the same board.So how to make then working using openOCD?I checked google a...
MSamy.1 by Associate II
  • 1245 Views
  • 3 replies
Resolved! STM32CubeIDE not able to set break point?
Hi,I have convert my project to C++.Debugging has no problem to show real time value etc. But I can't set break point as per normal, line number bar become blue line and all break point never stop.Please advise, thanks.
ST743 by Associate
  • 4262 Views
  • 3 replies
  • 6 kudos
