STM32CubeIDE (MCUs)
STM32CubeIDE 1.17.0 released
We are pleased to announce to you that the release 1.17.0 of STM32CubeIDE is available. What is new in 1.17.0: Microcontrollers, microprocessors, and board lists aligned with STM32CubeMX: Added the support for the STM32N6 seriesAdded the support for ...
stm32h747xx linker file modifications
Hello everyone!I have a quick question regarding memory allocation on an STM32H747XIHx MCU. While working with the linker file, I noticed the following memory definitions: MEMORY { RAM_D1 (xrw) : ORIGIN = 0x24000000, LENGTH = 512K FLASH (rx) ...
Change colors of context help window. How to ?
Hello,how I can change the terrible colors in context window in actual CubeIDE ? I see white background and white text. It is terrible. And  - by the way - why I can not instal the darkest dark theme ? I see a terrible error - see images below.
Code doesnt generate
Hi, for some reason, when i click on "generate code" main.c doesnt open, and i cant find it manualy either. Anyone knows solution? Thanks!
Plesnja by Associate
  • 121 Views
  • 3 replies
  • 1 kudos
Resolved! Any update to support macOS Sequoia?
Any news on when there will be an update to CubeIDE to better support macOS Sequoia?At the moment we need to use a terminal launch hack to get support for debug tools. Would be nice to get a fix for this soon.
KMill by Senior
  • 158 Views
  • 1 kudos
stm32h745 dual core run configuration
HiI need to flash both the cores of stm32h745zit3.  Tried to flash the code using STMCube ide. But after reset pin pressed, cm4 is not getting run. Using ide i run both cores separately. And using programmer tried to load hex separately but it doesn'...
Jpj.1 by Associate II
  • 133 Views
  • 6 replies
