STM32CubeIDE (MCUs)
STM32CubeCLT 1.20.0 released
We are pleased to announce that STM32CubeCLT 1.20.0 release is available. What is new in 1.20.0: Maintenance of the previous version: Updated in accordance with STM32CubeIDE v2.0.0Update of Clang toolchain version 19.1.6Update of GCC 13.3.rel1Update ...
Aimen1 by ST Employee
  • 353 Views
  • 0 replies
STM32CubeIDE 2.0.0 released
We are pleased to announce that STM32CubeIDE 2.0.0 release is available. STM32CubeIDE is now independent from STM32CubeMX. With this release, device configuration, previously handled within STM32CubeIDE via STM32CubeMX, is now exclusively available t...
  • 5356 Views
  • 0 replies
  • 4 kudos
Use LWIP in C++ main file
Hi every oneHow can I use LWIP TCP connection(socket, NetConn, Raw ... )  in main.cpp   ?I can use Raw in main.c properly but I need to use it in cpp files. thank you
MTora.1 by Associate III
  • 667 Views
  • 0 replies
STM32F4 Problem with USART
Hi, I want to use USART2 as transmitter on stm32f429zi mcu (nucleo board). I configure registers as in the picture, but transmission don't work. I use USART2 on PA2 pin and I need transmission with 115200 baudrate, alternate function is AF7 and usart...
[Debug] Software reset with bootloader
Hello everyone,on my MCU i've loaded a bootloader at address 0x0800000 and a dummy application at 0x0810000, but i'm experiencing some issues on chip reset button on the IDE. At first, when i debug the application no errors are encountered and the ap...
PGior.2 by Associate
  • 1709 Views
  • 4 replies
Resolved! STM32CubeIDE select target device
Hello,I have 2 NUCLEO boards connected to my computer and I don't see any option to select the target device when I run my project in STM32CubeIDE. I want to be able to run a different program on each board, how can I achieve that ?
Colus by Associate
  • 3444 Views
  • 1 replies
TouchFX on STM32F412G not working
Hi, I am attempting to generate a simple touchgfx project then I generate the code to transfer into an STM32Cubeide project on my STM32F412G Discovery board but every time I do I just get a greyed out screen like attached image is there something I a...
Linkpad by Associate III
  • 913 Views
  • 1 replies
Resolved! Inquiry about clock activation of stm32cube.
Hello?As the title states, I would like to inquire about the settings of STM32CUBEIDE(V1.13.1) of the STM32F730V8T product.If you select USB_OTG_FS (Dual/OTG, Host Only or Device only) for the relevant MCU, it will be activated in the clock, but USB_...
LSung.1 by Associate III
  • 1499 Views
  • 4 replies
