STM32CubeIDE (MCUs)
STM32CubeIDE 1.17.0 released
We are pleased to announce to you that the release 1.17.0 of STM32CubeIDE is available. What is new in 1.17.0: Microcontrollers, microprocessors, and board lists aligned with STM32CubeMX: Added the support for the STM32N6 seriesAdded the support for ...
STMCubeIDE USE_HAL_***_REGISTER_CALLBACKS definition
Hi all,I'd like to register some user defined callbacks using the HAL_***_RegisterCallback() functions. I understood that first I need to define the compilation flag USE_HAL_***_REGISTER_CALLBACKS but where should I put it? Looking through the variou...
LLea by Associate
  • 11551 Views
  • 28 replies
  • 13 kudos
No rule to make target `clean' ?
Hello,I use STM32CubeIDE v 1.4.2 It appeared today during the build my project:make clean make: *** No rule to make target `clean'. Stop."make clean" terminated with exit code 2. Build might be incomplete.11:48:08 Build Failed. 1 errors, 0 warnings....
Peko by Associate III
  • 6199 Views
  • 7 replies
  • 1 kudos
Resolved! CMake 3.20 or higher is required
HI I try to import my Stm32cubeIde project into VSCodeI have install STM32CubeCLTthe configuration failed with this error [variant] Loaded new set of variants[kit] Successfully loaded 5 kits from C:\Users\XXXXXX\AppData\Local\CMakeTools\cmake-tools-k...
LHOUE by ST Employee
  • 2348 Views
  • 4 replies
Host process of CDC (Virtual Port Com) does not work.
I am using STM32G0B1KC to make a CDC class USB Host.I selected in STM32CubeIDE, Mode=Host_Only (FS) in Connectivity - USB_DRD_FS and Communication Host Class (Virtual Port Com) in Middleware - USB_HOST.Before creating the user program, I checked the ...
JJ4IQV by Associate
  • 1722 Views
  • 7 replies
