STM32CubeIDE (MCUs)
STM32CubeIDE 1.17.0 released
We are pleased to announce to you that the release 1.17.0 of STM32CubeIDE is available. What is new in 1.17.0: Microcontrollers, microprocessors, and board lists aligned with STM32CubeMX: Added the support for the STM32N6 seriesAdded the support for ...
How to debug Lorawan from AN5481
Hi all,I'm working with a board build with STM32CubeWl, in the pdf file here section 5.3.1 it's say for debug swith the source code use APP_LOG, it's right in my source code I have APP_LOG, but my question is where is the output ? UART ? Form StLink ...
SBaro.11 by Associate III
  • 544 Views
  • 1 replies
CubeIDE open declaration leads to file.h
Hi everybody.Im using cubeide for a dual core mcu and when it generate code F3 keyboard button that opens declaration for that function will lead to the .h file. I want it to lead to the .c file.Once i did some changes to project properties c/c++ sym...
Command an actuator
Hi,i have a linear actuator that run with 6 voltsi want to control the speed using pwmi am using L298n and a nuceleo-g431rbhow can i reach the maximum speed? does the pwm maximum output 5 volts?
FBoua.2 by Associate II
  • 382 Views
  • 0 replies
how to use 'HAL_SPI_TransmitReceive_DMA' for spi
I'm using 'CUBEIDE' / 'STM32F107VC'in deca_spi.c int readfromspi(uint16_t headerLength,const uint8_t *headerBuffer,uint32_t readlength,uint8_t *readBuffer){uint8_t spi_TmpBuffer[BUFFLEN];assert_param(headerLength+readlength < BUFFLEN ); //    decaIrq...
kim_dy by Associate II
  • 597 Views
  • 0 replies
I2C slave transmit IT first byte FF
PLEASE DELETE THIS POST, I HAVE CREATED A  NEW ONE ON THE CORRECT SUBFORUMHi all,I am using a Nucleo  F334R8 STM32Cube FW_F3  V1.11.4I am trying to configure it as a slave device using interrupts , I am using HAL_I2C_AddrCallback()then it checks if d...
edgar3 by Associate
  • 664 Views
  • 0 replies
Error trying to launch STM32CubeIDE on linux!
I have installed the STM32CubeIDE 1.12.0 from the STM32 official website onto my Arch Linux laptop but when i try to launch it, it closes and reports an error after the splash screen.I have searched on pacman (the arch package manager) for stm32cubei...
RBamf.1 by Associate III
  • 14133 Views
  • 40 replies
  • 5 kudos
