STM32CubeIDE (MCUs)
STM32CubeIDE 1.17.0 released
We are pleased to announce to you that the release 1.17.0 of STM32CubeIDE is available. What is new in 1.17.0: Microcontrollers, microprocessors, and board lists aligned with STM32CubeMX: Added the support for the STM32N6 seriesAdded the support for ...
how to set CAN filter mask?
HelloI'm trying to set a filter but I can't.If I set, for example, the value 0x3 - all IDs with set bits 0 and 1 - (0x7, 0x13, 0xF, 0xF03......) pass through the filter.I guess I didn't understand this masking. Can you tell me what I'm doing wrong?I ...
PNova.2 by Associate II
  • 3996 Views
  • 1 kudos
Errors while compiling empty project
Hi. When I create SMT32 project (I'm using NUCLEO-L476RG) and then I compiled empty project I recive same 13 errors all the time(look photo below). I really can't fix it and I can't find the solution.What I tried: Reinstall STM32CubeIDE, didn't workI...
erysv by Associate II
  • 2894 Views
  • 12 replies
  • 2 kudos
Resolved! Load and start a programm in RAM with USB DFU
Hi,we try to load a small program to RAM area starting from address 0x20008000 with STMCubeIDE and USB DFU and select start address 0x20008000 ( In debugger we can see that program is load to 0x20008000).The download is successful, even so setting st...
clkr by Associate
  • 957 Views
  • 3 replies
Updating cube ide manually
I have internet access at my office only through a virtual machine.I'm facing an issue with updating Cube-IDE. Currently, I'm using version 1.11.0 and I want to manually update it to version 1.13.1.I've downloaded the executable file for version 1.13...
Pshar.2 by Associate
  • 2593 Views
  • 1 replies
Resolved! Timer Synchronization does not work.
Hello, hope this message finds you well.So, I'm on a project that requires multiple timers to generate 7 variable pulse waveforms in master/slave mode and I'm hoping to get parallel synchronization at startup, I'm using timer 1 as master, and timer 2...
JBazm.1 by Associate III
  • 3346 Views
  • 7 replies
  • 2 kudos
May I convert KEIL MDK-ARM to STM32CubeIDE?
Hi, I have some problem. anyone help me.I am not expert with STM32.I bought a STEVAL-D35R16B. it is RFID EVAULATION BOARD.I want use it. I downloaded demo firmware files.but I can not open it with STM32CubeIDE.Because it is for KEIL MDK-ARM.May I con...
Sellyette by Associate II
  • 1446 Views
  • 3 replies
  • 2 kudos
code stop in function HAL_I2C_IsDeviceReady
Hello, I am trying to use the LORA-E5 STM32WLE5JC board with the BME688 sensor, I2C connection. I used this repository as the basis GitHub - Squieler/BME68x-STM32-HAL: BME68x STM32 HAL Library, changing what was needed. But it always hangs in that ro...
