STM32CubeIDE (MCUs)
STM32CubeIDE 1.17.0 released
We are pleased to announce to you that the release 1.17.0 of STM32CubeIDE is available. What is new in 1.17.0: Microcontrollers, microprocessors, and board lists aligned with STM32CubeMX: Added the support for the STM32N6 seriesAdded the support for ...
Resolved! Synchronization between PWM signal and ADC
Hello! I'm trying to synchronize a PWM signal with an ADC (by TRIGGER OUT EVENT). There are 2 issues: 1. The frequency of the PWM signal is 200 Khz and the frequency of the ADC is 12 Mhz. According to the calculation of 14 cycles (12.5 cycles + sampl...
Resolved! Issue with multichannel ADC readings in stm32f334r8
Hi,I am working on interleaved buck converter for which I have to sense muiltiple voltage signals from current sensor,so I am using ADC1 of stm32f334r8. The problem what I am faceing is that if I vary the voltage on PA0 pin which is ADC1_IN1, the adc...
vasudev by Associate II
  • 636 Views
  • 1 replies
  • 1 kudos
Resolved! stm32f0xx_hal_can.h bug found, please fix it
Hello friends, I have been seeing the same bug in stm32f0xx_hal_can.h for some time, whenever I start a new project I correct it, but I would like you to leave it corrected to avoid correcting it each time I start a new project.The bug prevents to se...
RamiroGJ by Associate II
  • 744 Views
Resolved! strtok sets FLASH SR flags
I'm using the STM32CubeIde 1.12.0 Build: 14980_20230301_1550 together with the STM32Cube_FW_G4_V1.5.1 and FreeRtos.When I run the strtok the first time I see that the Register in FLASH->SR change the value from 0x00 to 0xe0. What later makes problem ...
Mat1 by Associate III
  • 1047 Views
  • 3 replies
  • 2 kudos
JTAG Communication with STM32F103ZET6
I am currently conducting verification on a custom board implementing STM32F103ZET6. During this process, I have encountered an issue with JTAG communication. The debugger I am using is the STLINK-V3SET.Communication via SWD: Communication using the ...
R.A by Associate
  • 1128 Views
  • 1 replies
CODE DUMPING ISSUE
 STMicroelectronics ST-LINK GDB server. Version 7.3.0Copyright (c) 2023, STMicroelectronics. All rights reserved.Starting server with the following options:Persistent Mode : DisabledLogging Level : 1Listen Port Number : 61234Status Refresh Delay : 15...
sram.1 by Associate II
  • 566 Views
  • 1 replies
HAL_I2C_Mem_Write Stuck
Hi everyone, i am working on a STM32C011F6P6i am trying to apply some I2C setting to other chipnormal writing value to corresponding addressbut seems the HAL_I2C_Mem_Write function is stuckedthese are the read and write functionHAL_StatusTypeDef i2c_...
RF Communication with 2 STM32F407VG disc1 boards.
Hi guys!I'm currently in charge of a project based on the RF transaction. My project is based to develop a system that have the ability to communicate with the RF transceiver, first I chose the AS4432SMD developed with the SI4432 transceiver and I tr...
Zayoud by Associate III
  • 1723 Views
  • 3 replies
