STM32CubeIDE (MCUs)
STM32CubeIDE 1.17.0 released
We are pleased to announce to you that the release 1.17.0 of STM32CubeIDE is available. What is new in 1.17.0: Microcontrollers, microprocessors, and board lists aligned with STM32CubeMX: Added the support for the STM32N6 seriesAdded the support for ...
Ethernet_F439_Error_Handler
 I am using a standard working example of STM32F429ZI on an STM32F439ZI. Usually if the pinout match, these codes work if the series differs also. But the Ethernet initialization is not happening and since the code is given by STM32 Cube IDE, unable ...
Resolved! Can't build imported demo project
Hi evryone,I'm trying to do some work on the stm32 L552ZE-Q and I'm trying to launch some demo projects available but once I've imported the porject in the IDE I can't build the project. I have that error:and I also got a warning but I don't find why...
_Louis__0-1736326859988.png _Louis__1-1736326906379.png _Louis__2-1736326944261.png
_Louis_ by Associate
  • 151 Views
  • 4 replies
  • 1 kudos
Adding a source file / folder to a project
Hello!One problem I had today:I made a new project for one specific question.In the process of doing this, I created a file. Let's call it test.c / test.h using STM32CubeIDE, V1.7, Linux.To start from the beginning, I added a source folder, and creat...
PG.1 by Associate III
  • 117 Views
  • 4 replies
  • 3 kudos
Package management, why to copy all files?
I'm highly confused. Coming from Keil MDK, I really enjoyed the CMSIS-Pack approach to manage dependencies. A MCU (and vendor) independent and efficient approach which works in command line and various IDEs (Keil MDK, VSCode with plugin, Eclipse). Se...
JKapp.1 by Associate II
  • 151 Views
  • 8 replies
  • 2 kudos
Resolved! Generate code not working in CubeIDE
Following up from my previous post, I am having issues with code generation - it seems to complete, but I don't see anything changed in the code.Here attached you will find the ioc file. I modified pin names for PB10 to PB12, but after generating the...
slai-nick by Associate II
  • 3427 Views
  • 10 replies
  • 7 kudos
Firewall blocking ST Login?
I can't login into ST to download packages via CubeMX/CubeIDE. The wheel turns forever, no matter what proxy settings I choose. The pack downloader works - I just can't log into ST which is a pitty.Which url does my corporate IT whitelist?See similar...
  • 149 Views
  • 3 replies
"main.c" is not visible.
"main.c" is not visible.This is the screen I want.  However, this is my actual screen. I am sure I have chosen the board correctly.
hjjang by Associate
  • 147 Views
  • 6 replies
  • 3 kudos
