STM32CubeIDE (MCUs)
STM32CubeIDE 1.17.0 released
We are pleased to announce to you that the release 1.17.0 of STM32CubeIDE is available. What is new in 1.17.0: Microcontrollers, microprocessors, and board lists aligned with STM32CubeMX: Added the support for the STM32N6 seriesAdded the support for ...
How to configure correctly path and symbols
Hello,I recover from a project but when I compile there are errors.And yet this file exists in the projectI think that in this tab the configuration is not correct, how can I change the configuration so that it is taken into account in my workspace ?...
DYann1_0-1734353731000.png DYann1_2-1734353905413.png DYann1_3-1734354049420.png
DYann.1 by Senior II
  • 341 Views
  • 5 replies
Setting up a C++ project for a NUCLEO-F446RE
Apologies for the newbie question, but I am trying to init a project with the following as starting point:STM32CubeIDE v1.17.0NUCLEO-F446REC++ DevelopmentFreeRTOSCAN Interface When creating projects it looks like there's a lot of options, but I can't...
drtarr_0-1733626887547.png drtarr_2-1733627144929.png drtarr_3-1733627575605.png drtarr_4-1733627678327.png
drtarr by Associate II
  • 264 Views
  • 4 replies
STM32CubeIDE showing errors on the GUI
Hi, I am using STM32CubeIDE version 1.17.0. I have compiled a project fine with no errors showing on the build console and the elf file is generated successfully. However, STM32CubeIDE is still showing errors on my project which, of course, are false...
hakeila by Associate III
  • 210 Views
  • 3 replies
  • 2 kudos
STM32CubeIDE is not connecting to the internet.
I had several versions of the IDE installed on my machine but none of them could connect to the internet to update or load code. I keep getting the error message "In order to benefit from best experience a network connection is required. Do you want ...
ADaxa.1 by Associate II
  • 13328 Views
  • 15 replies
  • 2 kudos
STM32CubeIDE 1.14.0 pattern recipe problem
Hi,I have project for STM32F405 created manually. Project is using fixed GCC 4.92014q4.After updating STM32CubeIDE to version 1.14.0 i got warnings shown below.Compiler option "Cyclomatic Complexity" is disabled.File "subdir.mk" contains this rule:# ...
Resolved! Build error
Hi, I tried to build my project but I faced these errors :--------------------------------------------------------------------------------------------------------------------------------------------------C:/ST/STM32CubeIDE_1.12.1/STM32CubeIDE/plugins...
Gnahore by Senior
  • 14161 Views
  • 10 replies
Resolved! 'mutex' in namespace 'std' does not name a type
Hi all,Very new to STM32, day 2 now, managed to get some UART output and call into C++.However when I try to use standard C++11 threads I get this error "'mutex' in namespace 'std' does not name a type". I believe this is bc arm-none-eabi-g++ is conf...
casaneva by Associate II
  • 722 Views
  • 7 replies
  • 3 kudos
Resolved! CubeIDE issue with G473 and USB Device CDC
Hello,I've found an issue in STM32CubeIDE1.17.0.When creating a project with USB Device used as a CDC Class and FreeRTOS an include is missing in app_freertos.c:#include "usb_device.h"The project runs properly, but a warning is issued at compile time...
zeboss49 by Associate III
  • 421 Views
  • 4 replies
