STM32CubeIDE (MCUs)
STM32CubeIDE 1.18.1 released
We are pleased to announce that the minor release 1.18.1 of STM32CubeIDE is available. What is new in 1.18.1: This minor release will not bring any major updates to the STM32CubeIDE 1.18.1. It will be aligned with the STM32CubeMX 6.14.1. Main fixed i...
STM32CubeIDE 1.18.0 released
We are pleased to announce that the release 1.18.0 of STM32CubeIDE is available. What is new in 1.18.0: Microcontrollers, microprocessors, and board lists aligned with STM32CubeMX 6.14.0: Added the support for STM32WBA6xxx microcontrollers in the STM...
Assistance with Ceedling through STM32CubeIDE
I am looking to use Ceedling for a unit test framework and want to use STM32CubeIDE's Unit Test support for running it in the IDE. I have successfully set up Ceedling and am able to run from command line, but it would be nice to at least understand h...
aw_von by Associate II
  • 983 Views
  • 0 replies
  • 1 kudos
Resolved! STM Compiler & & Operator
I am trying to understand what I am doing wrong here. The following image was captured during a debug session to show strange behaviour.In the If statement ap->enable and ap->active are both true, but ap->relay_map is 0, as shown on the right, so thi...
CYBR by Associate II
  • 2745 Views
  • 10 replies
  • 9 kudos
STM32F103 controller bootloader Jump
Hi,I am try to develop a bootloader for STM32F103C8T6 controller. my bootloader memory is 16 KB address range 0x8000000 to 0x8004000.my application range is 45 KB 0x800C000 to 0x8010000. jump statement I am using below mentioned one,void(*app_reset_h...
NandhakumarGanesan_0-1718607176359.png NandhakumarGanesan_1-1718607310008.png
Infinite loop in HAL_RCC_OscConfig - STM32G4 ?
Hi Community,I am working on a project with a custom board that uses both HSE (24MHz) and LSE (32.768KHz) clock sources. TIM6 is used as a time base source because SysTick is used by the RTOS. When running a debug session I can see that it is going i...
Guide for STM32 fmc nand flash
Hello,Can anyone help me with interfacing NAND flash with STM32H7 microcontroller? I am unable to find any reference guide or application note related to the same.-Regards
HDesa.1 by Senior
  • 3619 Views
  • 13 replies
  • 9 kudos
